Kaiser11
- Jan 28, 2007
- Lars
Hello,
This is my first post so many thanks in advance for any advice you can provide. I recently bought my first townhome and have a finished lower level basement that is 21' x 12' where my goal over time is to build that space into a home theatre room with HD Projector. There are 2 windows but light is not extensive and can be controlled. I will use the theatre primarily for movies, sports and video games. I have been researching these forums and buying every home theatre magazine I can get my hands on and am now stuck between 2 schools of thought and really need help- should I go higher end equipment and build over time (Option 1) or get all of what I can within my budget (Option 2). I currently have a 53" Sony rear projection TV that's 4 years old and not HD compatible so I will use that in the meantime. I also have a Comcast HD Tuner, PS3 and Yamaha HTIB that I'll be scrapping.
Option 1 ($3,500 budget):
(RECEIVER)-I have researched A/V receivers extensively and it seems the Denon AVR-4306 would cover all current and future needs so would be a solid foundation. My questions is would this be overkill for 1st serious home theatre in this space? $1,999
(DVD PLAYER)-Denon DVD 2930CI $849 Is this version significantly better than the 1930CI for $369? The model would allow me a @$1,000 for speakers. Are there any other similarly priced recommendations?
(SPEAKERS)- The DVD Player decision would impact my budget here so I'm torn. I think in a pinch I could use the Yamaha speakers for now and upgrade later but my preference would be to buy them now if possible.
Option 2 ($3,500 budget):
Is it realistic or even possible to get a full setup (HD Projector, receiver, upconverting DVD player, speakers) in this range? Would any HTIB solutions be powerful enough for a room this size?
Lastly- are there any recommendations for a HD Proejctor aruond the $2k range?
Any help and/or suggestions you can offer would be greatly appreciated!
