Ryan T
- Sep 10, 2001
Hello,
I bought this 10" original titanic 1000 driver a while back. I've been really itching for a good DIY project since I moved out to cali in september and I figured this would fit the bill. I had bought some Logitech Z-5300 computer speakers a month or so ago and I found the sub a bit lacking. It's a 6 1/2" driver in a bandpass box :/ It does make plenty of noise but it wont go very low and sounds a bit too boomy for my tastes.
I wanted to make a ported enclosure for the titanic for more extension. Since I only had about 2 Cu. Ft max that I wanted to use for the enclosure I was somewhat limited on how low I could tune it. I decided to go for the PE blow out sale port tubes 3" flared port 11 1/2" long. That gave me a tuneing point of about 27 Hz not too bad. The final design I made for the enclosure is 12" wide 19" high and 19" deep. I only put one shelf brace in which is skimping it a bit but I think its good enough.
Making the enclosure without my grandpas table saw and router was a bit of a challenge. I used a 10" circular saw and my jig saw for the construction. I knew I needed a saw guide so I got a metal level and some 2" spring clamps. I used that as my guide and it worked pretty darn good. I have a few spots where I need a bit of wood filler because the MDF got chipped off but other than that its pretty square.
I'm planning on covering it with the PE black textured laminate I used on my AV 1's. It has held up very well and you cant tell its peel and stick unless you look very closely
. Heres the big problem I ran into with the subwoofer though. When installing the driver I popped and jammed three tee nuts! I didnt have much clearance at all between the tee nuts and the outside of the driver hole so I put them as far away as possible bad idea. So now I cant get the driver out unless I drill the screws out or ruin the enclosure :/. I still think i'm going to be able to use the laminate. I'll just have to make a template of the face of the sub and transfer that to the laminate and try to apply it around the driver and port tube.
Heres some pics
http://geocities.com/ryatod/sub.html
Ryan
Heres some pics
Ryan
