Kieran Coghlan
- Oct 26, 1998
Would someone who owns an XBox, the HighDef-kit, a widescreen high-def TV, and the game DOA3, please do a favor for me?
Will you disconnect the component video connection from your XBox to your TV, and instead hook up the COMPOSITE video connection. Leave the XBox's settings for widescreen as is. Now play DOA3 (since we KNOW that DOA3 supports 16:9). Sure the resolution is much less (480i vs. 480p) with composite, but is the widescreen (anamorphic 16:9) image intact?
I'd really like to know if the widescreen gaming feature works over the composite (and/or s-video) jack, or if it only works over the HD-component outputs.
Thanks a ton!
Thanks a ton!
