Wade
- Jun 30, 1997
My original question regarding sub size and placement was asked HERE . I liked the SVS sub that was recommended in that thread but I don't know if it's the right way to go. I am torn between utilizing one sub, like the SVS, or utilizing two subs for a much more elegant layout. I'm not sure how two smaller subs would compare to the one larger sub though.
In this FLOOR PLAN you can see I had three locations marked out for utilizing one sub. The problem is the two niche locations are only 24" deep so the single sub would be relatively small for the room size. The location outside the niche would be okay except for I don't know what's going into the room just yet. So I could end up blocking it with something later. The wife doesn't want to be restricted in placing things in that area because of a sub.
With all this in mind I've decided to try to place two smaller subs in the corners of the niche as shown in this ELEVATION . I've shown the larger SVS PB2-Plus outside of the niche to show the scale of the room. I don't know what make or model the two smaller subs would be. One more thing to point out is the flooring in this room is carpet over concrete.
Now for the questions:
1) Would utilizing two smaller subs get close to the performance of the one larger sub?
2) Would elevating the two subs improve performance? If so, what is a good height from the floor?
3) What type of sub would be best for inside the niche (sealed, rear port, down firing, etc...)? I would most likely have a built in done so each sub would have it's own compartment. This brings up my fourth question.
4) Depending on which type of sub was chosen how much larger would the niche compartment have to be in order to give the best performance? This is the tough one.
I think that's all for now. I wasn't sure if this should be posted here or in the speaker section. It's fine by me if it should be moved.
Wade
Wade
