ChrisA
- Nov 25, 1999
Sure it is misleading. I don't see them clarifying the difference, quite the opposite.
Link Removed
Link Removed
I believe everything so far has indicated that HD-DVD will be backwards-compatible with today's DVD players. Of course this means complications - for example if the new HD-DVD format features completely different audio compression (or the lack of compression) a regular Dolby Digital or DTS track would have to be included on the HD-DVD discs as well in order for it to be a 100% backwards-compatible. And either the discs would have to contain two video tracks (480i and 1080p) or downconversion to 480i is necessary.
HD-DVD *players* will most likely be back-wards compatible with SD-DVD software and CDs...just like today's DVD players play CDs too.
But HD-DVD *discs* may or may not be. It totally depends...most likely they would not be but it would be cool if they could be made in such a way that one layer(s) or side is SD-DVD res and the other layer(s)/side is HD.
I want to get free from compression artifacts and have some *real* audio for a change (not talking about no compression, just to compresion *artifacts*). Give me perfect transfers with no trace of digital compression and give me 7 channel 24/192 or DSD auido!!! (lossless compression would be fine for the audio).
-dave
The best Muse discs beat DVD. The worst are worse than DVD.
That'd be me...
River Runs Through It and Dances with Wolves(4 hour version) look significantly better than the DVD counterparts (which are scaled to 1365x1024 and run through an anamorphic lens).
Top Gun and A League of Their Own were worse than the DVD.
Then again, this weekend we watched some D-VHS tapes of HDTV material and Ronin looked better than the DVD, but negligible (maybe 10/20% in detail). Titanic was significantly better than the DVD (no surprise) while Caddyshack was almost indistinguishable from the DVD version (colors were a little more saturated, but MINIMAL)
Everything varies from transfers to compression, HDTV doesn't always = 100% better
-Brian
PBS HDTV which is shot with HDTV cameras looks so good when line doubled to 1080P that I can sit less then one screen height away and the picture is still wonderful. I find it much better then any movie theater.
I've been watching HDTV movies for over two years and I've never seen anything as good as what PBS shows every day.
Frank (and Chris too),
Would love to see some pics of that HT of yours!!! Any website or links?
-dave
[Edited last by DaViD Boulet on November 06, 2001 at 03:05 PM]
