Ricky c
- Aug 28, 2001
If you had this system:Marantz sr7000,Def.Tech. Procinema 100's w/200tl sub,Yamaha cdc665 cd player and Panasonic rv30 dvd.Also 1,500.-2,000. budget what would you change or upgrade if anything.I like this system but am looking to make it better within the budget if it was possible.I also have a Panny 36hx40 HDTV which i wont change.The room is 22.5x19.5x8'.Or should i leave it like it is.In other words with this budget would there be a significant upgrade.Also would just adding a 5 channel amp be considered a significant upgrade.Or am i going thru upgraditis.Thanks
