Sacha_C
- Jan 13, 2003
My receiver has plugs for Control A1II, what exactly is this used for?
That's a proprietary link Sony uses for allowing certain Sony equipment (mostly MD players)Actually most of the Sony stereo components provide S-Link capability. My 50 Disc Sony CD changer from about 6 years ago has it as does my Sony DVD player. And as far as I know, all the A/V rated (that is the ones that are actually component width) Sony VCR's have it too. I also beleive even many of their better TV's do.
And from what info I can find, it looks like if you have one of the newer CD chagers that supports disc titling and have one of the fancier Sony receivers with the two way remote, the remote can even pull disc titles from the receiver over the S-link to the changer. Although I haven't had a chance to actually try this since my changer is older than dirt. In my case though, I can at least get status transfered to the remote as to which slots in the changer have a disc present.
Pretty cool stuff really, but like others have mentioned about, it requires you to have all your components from the same vendor to really make use of it. This hopefully will change though in the next couple years as vendors hopefully start supporting firewire and HAVI.
