Ian_H
- Aug 6, 2001
Hello all!
I have a question for everybody. I want to upgrade to Dish 500, mainly just for the ability to get my local channels. I currently have the regular Dish Network setup with the model 4500 receiver. It has the capability to receive both satellites as there is a dish 500 check box in the signal set up. Here is what I need to know. I won on ebay a dish 500 dish but it does not have the LNB. Can I use my current LNB? The LNB I have you can hook up two receivers. My thinking is that I can use my LNB and use the sw-21 switch. Will that work??
Thanks in advance!!
--Ian
Thanks in advance!!
--Ian
