Nick.Y
- Oct 22, 2002
I want to get your opinions on the best upgrade path for my current system which consists of:
Pioneer VSX-811s (Acting as Pre/Pro)
Parasound HCA-855a (External Amp)
JBL N26II (Fronts)
JBL N24II (Surrounds)
JBL NCenterII
Sony WM40 Modified
AudioQuest Sidewinders for Interconnects
I added the Parasound about 5 months ago and it definitely enhanced the original set-up. Recently added the AudioQuest Interconnects and I notice a slight enhancement. I'm at a point now were I want to add additional depth and clarity to the system and perhaps open it up more, particularly for Home Theater.
My thoughts are to replace the 811s with something like the new Yamaha RX-V1400. I no this is not a dedicated Pre/Pro but my budget is limited and with the YPAO feature I think it would be a definite enhancement over the Pioneer. I would even consider a dedicated Pre/Pro from Outlaw, but would the Outlaw be that much better than the Yamaha?
or
Replace the JBL's with another manufacturer. Paradigm's? I've been looking at the Moniter series. Will the Paradigm's be a vast improvement over the JBL's? Without updating the Pre/Pro.
Right now, I'm leaning toward trying out the new Yamaha? My gut tells me this is where I will notice the most improvement. Right now, I'm around 70/30 HT/Music.
I want to keep the upgrade to under $1000.00 if possible.
Any insight/opinions from others will be greatly appreciated.
Thank you for your time.
Nick
JBL N26II (Fronts)
JBL NCenterII
Sony WM40 Modified
or
Nick
