buggs
Grip
- Aug 4, 2006
- Scott
I am building out a dedicated home theater in a 15 x 16 room. I have a set of axiom Epic 50's and a Carada 106" 16:9 screen.
My questions:
1. Center channel- I have three choices for placement: I have a shelf above the screen at approximately 8 feet so I could place the center channel on this shelf, I could mount it on a bracket just above the screen or I could mount it under the screen. Any suggestions?
2. I am considering building the subwoofer into the back wall near the back corner of the room. The front of the speaker would be on the same plane as the wall. The cavity would be large enough that the woofer could be angled slightly if that would make any difference. Asthetically, and space wise I like this idea, but will it impact my sound quality?
Thanks, Scott
My questions:
Thanks, Scott
