Daniel Marx
- Jan 26, 2000
Just set up a Driect TV Plus 18"x24" Eliptical dish, with two dual LNB's. I need to distribute the sat signal to a minimum of 8 recievers (two hi-def and the rest just standard). I was planning on using an 8 port multiswitch but upon looking at the multiswitch that came with the sat, I'm suddenly confused how a standard multiswitch could work. Standard multiswitches take the LNB A and LNB B and make anywhere from 4 to 24 additonal receivers. The dish however labels both LNB's A on the one side (101) and both B on the other (119). The multiswitch it came with allows only four receivers to be connected. How can I use that multiswitch along with the standard ones to get me at least 8 signals for 8 receivers?
Dan
Dan
