Nat Ward
- May 23, 2003
I'm trying to decide what shape to make my PR'd Tumult enclosure and was curious as to what size you guys made your base cube. Taking the tape measure to the back of the Tumult and PRs, then using AutoCAD it doesn't like like you can use much below 22.5" before the baskets start touching. I look around though and see people making 24" exterior cubes with 1.5" walls, so my measurements must be pretty conservative. What did you guys use with success? 21" base cube? Thanks.
Nat Ward
Nat Ward
