Jeff Meininger
- Jun 5, 2002
I'm thinking of upgrading my cheezy sattelites (crossed over at 120 Hz) to some floorstanding tower speakers at some point in the future. My Onkyo SR500 receiver allows crossover settings of 80, 100, and 120 Hz. If my towers are -3db at 40 Hz, wouldn't I want a crossover setting of around 60 Hz?
In other words, with an 80 Hz crossover, aren't bookshelves with an F3 of 60 Hz every bit as good as towers with an F3 of 40 Hz (all else being equal)?
I thought my entry-level receiver might simply have more limited options when compared with better receivers, but it turns out the Onkyo SR600 and SR700 also limit your choices to the same 3 settings.
So what's up with bass-management and tower speakers? If they're too small to run full range and have to be crossed over at 80 Hz, are they a waste?
I couldn't find anything that quite answers this question in the HTF "primer for home theater newcomers". It seems like this question would be in FAQ territory, though...
