Michael Langdon
- Aug 29, 1998
I just received my Stage One (DD,DTS, THX Surround EX, DTS-ES Matrix and Discrete, DPLII, DTS Neo:6, THX Ultra2) this weekend. I previously used a Denon 5800 as a pre/pro. First, the best thing about the Stage One is the setup. Speaker configuration is normal (large, small, 1 or 2 surround back, etc.). Speaker levels can be set in 0.5 db increments which means worst case scenario is a speaker 0.25 db different from another! Speaker distances can be set to the nearest inch! That's right, the Stage One claims a 1/12 ms accuracy on delay! Crossover availability is also the best I have personally found. Crossover (global) can be set from 25 to 120 Hz in 5 Hz increments. Speaker levels can be adjusted and memorized for each mode (DD, DTS, DPLII, etc.).
Even though the setup for surround is great, the best part is that I can have a different configuration/bass management for stereo listening modes! Yes, I can have 2 different crossovers, one for surround and one for stereo which includes a different speaker configuration.
My example:
Surround:
Fronts-small
Center-small
Surround-small
Surround Back-small
Sub: Yes
Crossover: 65Hz (based on the highest low freq. response of all speakers in my setup)
Stereo:
Fronts-large (fronts are towers rated to 40 Hz)
Sub: Yes
Crossover: 40 Hz (to match freq. response of fronts)
or
Fronts-large
Sub: No
Previously, with the Denon, I had to re-enter the menu and change my speaker configuration. I had no control over the crossover point. Now with the upgraded 5800 I would have 40, 60, 80, 100 and 120 Hz but I would still have to change it back and forth for surround and stereo listening.
After setup, I listened to the Stage One with a few familiar movie clips. The short list was DTS Demo discs 3, 4 and 5, scenes from Blade, Phantom Menace, Matrix, Fifth Element, Terminator 2, Jurassic Park (DTS), Desperado (Superbit), and Super Speedway (new DTS version). The first thing that came to mind when listening to the Stage One was Dynamic Range. The Dynamic Range was so much greater with the Stage One over my previous Denon 5800! The Denon 5800 seemed compressed. Dialogue was much more clearer in the Stage One. My center channel (Boston Acoustics VR12) has never sounded as good. I really expected the sound difference to be more subtle since I was not buying a Lexicon or the like and the fact that the Denon is a flagship or previous flagship receiver. I am truly amazed at the difference in having true separates (since I was using the Denon 5800 as a pre/pro already having external amplification).
Well, I will be giving the Stage One a thorough workout in the coming days. I will have more impressions to post, but I thought I would give my initial findings in the setup and first few listening experiences. Also, the blue lights on that silver finish sure does look pretty!
Mike
Stage One
My example:
Surround:
Fronts-small
Center-small
Surround-small
Surround Back-small
Sub: Yes
Stereo:
Sub: Yes
or
Fronts-large
Sub: No
Mike
Stage One
