Hello, and thank you for helping me out.
I'm new to hi-fi setups so please excuse if I don't provide enough/relevant information, so please do not hesitate to ask anything that might help you help me.
I have a Denon AVR-X2500h audio receiver which has the following specs in terms of power output:
-Power Output (8 ohm, 20 Hz - 20 kHz, 0.08% 2ch Drive) 95 W
-Power Output (6 ohm, 1 kHz, 0.7% 2ch Drive) 125W
-Power Output (6 ohm, 1 kHz, 10% 1ch Drive) 185 W
I do understand these are power ratings at different impedance loads, however it says 2 channel drive, what about a 5 or 7 channel setup such as the one I want? Is the drive still 95W @ 8 Ohm or 125 W @ 6 Ohm? This confuses me and makes me worry for reasons I'll elaborate now.
I went to a Yamaha local representative that suggested a Yamaha audio receiver with similar power output but higher THD, coupled to the following speakers:
- Yamaha NS-P51 Nominal Input Power: 60 W Maximum Input Power: 180 W Centre and 2 surround speakers
- Yamaha NS-F330 Nominal Input Power: 50 W Maximum Input Power: 200 W Tower front speakers
- Yamaha NS-B750 Nominal Input Power: 30 W Maximum Input Power: 120 W Rear speakers
All are 6 Ohm speakers.
I am worried because both my Denon receiver and the receiver suggested by the expert at Yamaha exceed the nominal ratings of all the speakers, this is my main concern.
Also, if there's something I'm missing about the setup proposed and it will work fine with my receiver, I'd like to know how these compare to a Focal Audio Dome 5.1 speaker set.
Thank you for helping a newbie out.
