SVS question again (1 Viewer)
Takosan
1. if you need to add a 2nd sub after-the-fact & you get a PC model can you just use a Y-cable(?) or something & use 2 PC models?
2. when was ETA on PC+ models (equivalent of CS+ but with amp)?
TIA,
SteveBjr
You'd probably be better off sending the PC back and going with 2 CS subs/amp combo. But i suppose you could just use the Y cable to run 2 PC subs.
webbhcjr
