Brett Loomis
- May 9, 2001
Before I go buy all the electrical items for my basement HT that I am starting to build I wanted to ask for advice/suggestions on electrical outlets....I've seen the el cheapo ones for $0.69ea and have heard many recommend buying Commercial grade outlets. Can someone please help me understand what's the diff'? FWIW, I will be using approx. 18 Halo recessed cans and 6 to 8 Halo eyeballs for wall lighting of Movie Posters. I will be using 12/2 wiring for all audio and lighting with audio on separate circuit from lights to avoid noise.
Will also probably buy Lutron Spacer w/remote (4 zones) from HD at about $65 each....Grafik Eye is aa a little to pricey I think compared to Spacer 4 zone comparable...
What am I forgetting??? Please help.
Thanks, Brett
Thanks, Brett
