kyutaek
- Jan 22, 2004
I have some questions about the selection and placement of my first subwoofer. I will get Epos ELS-3 (main and center, on order) and want to buy a subwoofer. I am not a big fan of loud music, but need one for better(tight) bass sound.(70% music, 30% movie).
How do I select a brand/model(size) of subwoofer. Does bigger size (12, 15") mean that I have to play them in a louder volume (to get their bass potential maximized) and thus, more vibrating (sound transmission) throughout the whole room and (possibly) neighbor (I will put it in a hardwood floor with another townhome attached)? If my listening preference (at a lower volume) and possible trouble with my neighbor are closedly related with the size of subwoofer, I would go with smaller (8 or 10").
Also, I want to put a subwoofer in a shelf of my entertainment center. My wife doesn't want to put it in better position (front corner of the room, right next to the wall) for cosmetic reason). The bottom shelf is made by wood and there are two glass shelves upward. Is there any vibrating (and possible damage to the entertainment center) if I put subwoofer there? If it is true, any equipment to minimize vibration which enables me to put there?
I am currently thinking either HSU STF-1 or STF-2 (budget $300 -$400). Given the information, if you comment my selections and/or suggest any better model (to suite my needs)
