SSX tricky sound ? (1 Viewer)
David_Merrow
I just got an optical cable for my ps2 and wanted to try the dts decoding on SSX tricky. When I select DTS on the sound option menu I get no sound but my receiver says that it is getting a signal. Has anyone else had this problem?
thanks
David
Dave Bennett
A few things.
First the obvious. Do you have a DTS capable reciever? Not all reciever do DTS some only do Dolby Digital.
If so, go into the menu of the PS2 and make sure the optical output is turned on. You should hear all sounds produced by the PS2 through the optical output if it is working properly. Now go into SSX Tricky and chose DTS for the sound. If that doesn't work, perhaps try a different optical cable?
Staff online
almico
