I am planning my basement home theater room and have purchased some speakers (JBL satellite sc 200) that I would like to mount in the wall and then cover with fabric the same color as the paint the wife picks out.
BAsically build boxes in the wall framing, place speakers in and then cover with the fabric.
I was going to go 4 rears behind, 3 fronts and center up front and sub in the corner.
Has anyone had experience doing this or any suggestions?
I have searched the forums and not found anything.
I am also looking at ways to sound deaden the room. I have jammed the floor joists with R20 insulation and am insulating the walls with the same. However there are cold air vents and heat vents that seem to carry sound and I was wondering the best way to shut em up?
Thanks for the great forum, I didnt know I didnt know so much about home theater till I started reading here.
