I am going to buy a dremel finally to do some little things, I was wondering if I could use that to make my sub flush to the box? Also what would I need to do that if possible?
It would be best to use a router. If you are using a 3/4" baffle, add another layer. Of course, cut the holes bigger on the outside layer.
The only thing is that I don't have a router, and I dont have room yet to start buying tools. All I have right now is a Jigsaw and drill. Enough to make a nice sub box actually, I just want to make it a little nicer looking. So there is no way to do this with the dremel with some sort of attachment?
You can try with the Dremel but it's going to take more than 4 cuts.. there's not enoungh diameter on the tool to cut. Great for drywall though..
Well I had no problem cutting a circle for the sub using the jigsaw. I was just wondering about making it flush with the box. But now I have to look into buying a router then.
I agree. Buy the router. Get a cheap one for $60. It can do wonders. I also have a dremel with a routing extension. I tried to use it on 3/4" MDF and it was a joke. It would take 10 passes to cut out the width you need to flushmount a subwoofer.
The dremel would be great for cutting veneer though.
