brettecantwell
- Oct 10, 2012
- Brett
Ive been tinkering with my setup and my receiver has a test tone to set the speakers to be equal.
I dont really know how accurate this would be...but i tried using a sound meter smartphone app. I can get the fronts, center and surrounds within 1-2 db easily. The problem is when i go to set the subwoofer... If i set it to the same dB level the i have to crank the sub up ALOT ( on the knob and in the AVR).
If i set the sub to the same dB as the mains the sub seems like its WAY too much. It seems like the best subwoofer sound is with it set 10-15 db less according to the smartphone app.
Once again i dont really know if this app i tried using is a good accurate tool to use. I dont really even know what the proper method is really...
Any input is greatly appreciated.
