Hello and thank you in advance for any help you might be able to share. Currently setting up a home cinema which combines
55" Bravia EX500
HTCT100 Sony Sound Bar
400ES Home Theater Receiver
BDPN460 BluRay Player
I need some advice on how to connect my components together.
Do I connect everything to the receiver then output to the TV
or do I hook everything up to the receiver excluding the sub base then output to the sub base then to the TV. I've attached the diagram for the Sound Bar's Sub base and the receiver.
http://i59.photobucket.com/albums/g286/fhosenilla/SubBase.jpg">
This is the image of the back of the sub base
55" Bravia EX500
