some Quick Denon 3805 help please!! (1 Viewer)
TimZ
i am wiring up all my speakers but i can't tell which to attach my 2 surround back speakers ( 7.1 ) on the receiver.
Du i connect them to the Surr.Back / Multizone speaker connections or do i use Surround B connections??
If I do use the srround back/ multizone connections then wtf are the surround B for?
yes i know i am a newb :)
JeremySt
Jeremy
Use Surround A for your side surrounds, and the surround back outputs for your surround backs. Surround B is identical to the surround A, it just lets you hook up another pair of surround speakers, and A-B switch between those and the A speakers. It should not be used siimultaneusly with the A surround speakers.
TimZ
thanks a lot. thats what i was thinking but the way the manual worded it confused me.
This is my first fairly high end receiver .
jxreynol
