Coy
- Oct 23, 2004
Our plans are for a dedicated Home Theatre in the new home we are building. It will be in the basement (two walls concrete) with room dimensions of 10' ceiling, 16' wide and 23'4" long, with two risers - first riser starting 15'4" from the front wall and extending 4' back, with the second riser immediately following.
FIRST QUESTION - how high should the risers be?
SECOND QUESTION - should we "pour" the risers (and stage under screen) to include them with the concrete when the floor is being poured, or should we build them after the floor is in?
THIRD QUESTION - what screen size would be best for the room dimensions I have outlined, what would be the optimum viewing distance, and what would be the best height for the screen from the floor?
FOURTH QUESTION - front and center channel speakers - should they be mounted to the side and below the screen, or should we incorporate behind the screen speakers?
FIFTH QUESTION – should the 7 channel surround back speakers be placed on the back wall, with the 2 side surrounds positioned in line with the first row of seating?
SIXTH QUESTION – one or two subs and the best placement?
SEVENTH QUESTION – is it best to rack all components towards the back of the room? What type of venting is best?
EIGHTH QUESTION – what is the best method for soundproofing and what is the best floor covering?
Answers to any of the questions would be greatly appreciated.
Also, any suggestions you may have that would make the HT go together a little better (easier) are also welcomed.
Thank you!
Coy
Thank you!
Coy
