Garret_O
- Sep 11, 2002
Hello all,
Quick question. I want to router out 3/4" on the top and bottom edges of my sub box so I can put 3/4" walnut strips in there. That way the sub will match my mains, oak with walnut strips.
Any suggestions on the best way to do this?? Would a 3/4" rabbit bit at a 3/4" depth be the best way to go??
Any suggestions would be great, Thanks.
Edit:
Doesn't look like there are such bits, best you can do is 3/4" by 1/2" inch depth. Would a 3/8" look ok or just cheesy? I'm guessing cheesy. So wold you take the chance on a straight bit- getting everything straight and in-line?
Edit:
