Daniel Becker
- Dec 31, 2002
I have a quick question about adjusting my Wega. I've been told the "warm" setting in the Wega's menus in the NTSC standard for picture warmth. The "normal" setting is lableled "pro monitor" like. What is the appropriate look for movies? Do movies follow the same NTSC standards or are most movies made to be viewed in the "normal" type of coloring?
Also, the only reference option I have for tweaking is the THX optomizer found on many of my dvds. I've adjusted everything and it all looks nice and I clearly noticed an improvement after using the new settings for movies. But i've had one problem that I can't seem to fix. There is this one particular test which shows a circle in two boxes and the boxes are suppose to show perfectly straight lines and the boxes are both suppose to be visible. Well, on my set it's displaying the circle very nicely but the second outer box is missing it's left side. It's viewable when I tweak my service menu and pull it over but here is where the problems come in. I've altered the horizontal size so the boxes fit perfectly and all four sides are clearly visible. Then I turn on a Gamecube game and i'm now seeing the sides of the screen not being used %100 now. Not to mention the screen is not perfectly centered. Then I turn on a movie and it looks perfect. Then I turn on the weather channel and it's not perfectly centered and i'm missing a little bit of text on the side. So what i'm saying is that it seems no matter how I tweak things i'm off on something. It's like they're all not perfectly centered. What gives?
Dan.b
Dan.b
