Chris_Cur
- Dec 1, 2002
First, a pre-emptive statement to Chu Gai: With no disrespect intended, I'm well aware of your feelings regarding Monster products, as well as your feelings that people would be better served by buying separate insurance. I'd really like to stick to the question presented here rather than having the thread derailed back into those points.
This question involves the following two products:
1. Monster's HTS1000 ( http://www.monstercable.com/power/pr...r.asp?pin=1901 ): This is a typical Monster surge protector, and it comes with a $250,000 connected equipment guarantee.
2. Monster's SW 200 ( http://www.monstercable.com/power/pr...r.asp?pin=1218 ): This device is designed to plug-in a remotely located subwoofer. It comes with a $50,000 connected equipment guarantee.
The HTS1000's warranty information says the connected equipment warranty is invalid if "if any wire (phone, coax, or AC), or audio or video interconnect leading into the equipment comes from a component that is not properly protected by the Monster PowerCenter." I'm assuming the SW 200 contains a similar clause.
Here's my question:
Is there even any way to use the SW 200 without voiding the warranty for one or both systems? Assume you have the following basic setup:
1 TV, plugged into the HTS1000
1 Receiver, plugged into HTS1000
5 Speakers, plugged directly into the receiver.
All coaxial/telephone/etc. cables plugged into the HTS1000
Now, if you wanted to add a powered sub to the mix, I know you can plug it into the HTS1000 and still be covered. That's fine if you have your sub setup next to the rest of your equipment, or if you want to run a long extension cord. For the rest of us, it's a problem to figure out how to connect a sub to the rest of our system.
I'm assuming the SW 200 was made with precisely that problem in mind.* Let's say I hook the SW 200 up to a different outlet, and then I hook the sub up to the SW 200. Now both ends of my system are protected by Monster products, but that leaves open the question of what sort of coverage that brings. If lightning hits my house and ruins my TV, what stops Monster from saying the HTS1000's warranty is invalid because some of my equipment was plugged into the SW 200, and the SW 200's warranty is invalid because some of my stuff was plugged into the HTS1000. And even if one of the warranties stays in effect, which one would it be? The $50,000, the $250,000, or both?
*: I say this because Monster's plug for the SW 200 reads as follows: "Your subwoofer is probably placed too far away from your main system to plug into a surge plug strip. Why use another plug strip just for a subwoofer when you can just plug into a nearby wall outlet, right? Well, consider this. If a power surge strikes and your subwoofer is unprotected, it may cause some serious damage not only to the sub, but your entire home theater. The surge can also travel unimpeded from the subwoofer to your other home theater components, via their interconnect cables."
and
"With SW200, you can place your subwoofer away from your main system and always have the best possible performance and surge protection."
Here's my question:
and
