MarcosArbelo
- Oct 30, 2003
First of all I am new to ths forum, stumbled upon it doing a search and let me say I have learned so much in the last couple of days just reading through some of the post. So thank you to the moderators and administrators for accepting my registration here.
I recently purchased a Denon AVR2802 6.1/7.1 and I am using some old 5 surround speakers I had with an old set up they are pioneer with a passive subwoofer they are old and do not sound that well at all. I want to get the best that I can out of the receiver for a home theatre effect so I am looking to upgrade the speakers.
My questions are should I buy 5 satellite speakers and two towers to run 7.1 without a sub, or should I get a sub instead of two towers. What are your guy's thought's on theatre sound with towers instead of a sub? Or should I get both.
Is anybody here running a set up with a Denon, thought's on Denon?
Can you guy's suggest speaker brand as well I would like to get as close to the best theatre sounding speaker as I can. My budget right now is $1000 dollars for the speakers even though I will probably end up spending more.
I appologize I am not as techical as some of you so please educate me.
Marcos
Marcos
