Question for 4805 owners (1 Viewer)
Dan Kolacz
Hey!
How does this projector handle 4x3 material like an Xbox?
Does it have a stretch mode? How is it?
Can it also display it in the correct 4x3 format? If so, What happens on the sides?
Also, what screens are you guys using? I would like 100".
THanks
Scott L
1) Handles it fine, it can stretch it or keep it native, whatever you want.
2) Stretch mode works good, on board Faroudja processing makes the picture smooth and sharp.
3) Yes. Sides are black.
4) I'm using a $40 DIY Parkland Plastics 80" screen painted with some of the mixtures detailed on AVS. On my 3rd mixture and I'm almost satisfied. ;)
phyllisbernhard
