Question about JBL SCS 135 (1 Viewer)
Niel_JL
Ordered it yesterday from J&R. Does anyone know if this comes with a cable to connect the LFE out from receiver to LFE in from subwoofer. It comes with plenty of speaker cable, which is not the same(I think). The salesguy on the phone didn't know, and the owner's manual wasn't clear, or maybe it was clear but since this is my first sub, I'm a little clueless :b
Jeremy Little
No, I just put one of these out at Best Buy. It comes with speaker wire, mounts, and book. That is all. You'd want to pick up a good cable with tight RCA connectors for the best sound.
DevinL
Grip
I've also tried using a Y-cable for the subwoofer. I think it was better with the Y-cable.
Matthias Schulte
