Greg P
- Jan 7, 2001
I have just finished my sealed 1503 project. I am using t-nuts into the MDF to mount the driver. I have 2in 10-24 size screws. The sub is a small cube, so on 4 of the 8 screw holes the t nuts extend infinitly into each side wall. On the sides that dont I only have an 1.5 in of thickness. On those hole mounts I notice one of the screws swelled up the Mdf and put a small crack in the back layer. I drill as much as I could out with the T-nuts already in. Should I just get shorter screws or is there somthing else I can do.
