Vito_Jr
Grip
- Oct 15, 2002
Hi, I just had "digital cable" from att installed. Most of the channels look great on my 42" plasma, but the local (4,5,7) channels are somewhat grainy. I have to play with the coax cable to get a clearer picture - It reminds me of the old rabbit ears.
Once I have it tweaked the picture is very acceptable - not as crisp as the "digital", but clear enough (no static or grain).
I am suprised that with a coax connection I need to move the cable around for the different channels (4,5,7).
Are there better quality cables and connections that will give me a clear picture without having to play around the cable? I am using the stock coax that came with the cable box - it has the screw-on type connector. And I am feeding the video out from the vcr into the bnc connector on the plasma.
Thanks...
Thanks...
