Hoang
- Apr 7, 2003
Hello all,
I'm just getting into HT and need your advice and opinions. I currently have a very low-end receiver that is only used for audio...no surround sound yet. I would like to replace this with a pre/pro and amp. The speakers I have right now are also very old...Cerwin Vega D-9. I will keep these for the time being.
I would like everyone's opinion on what pre/pro and amp I should get. I plan on starting with this first then move on to adding/replacing speakers later on. I would like to spend about $1500-2000 for the pre/pro and amp. I have started looking at Rotel, Parasound, B&K and others. I would like my equipment to be reliable also.
Thanks in advance for your help.
Hoang
Hoang
