Dennis Palla
Grip
- Sep 18, 2003
- Dennis Palla
This room is dedicated to movie and music entertainment. It is approximately 12x17 originally designed and constructed for sound reproduction. The walls are 2x6s covered with 3/8in plywood, 5/8in drywall and floated with plaster. The corners are all concave radiused including where the walls meet the ceiling. The wall behind the seating area is also curved with about a three inch relief. The ceiling is rising to the middle with a six inch relief. The purpose was to eliminate parallel surfaces thereby reducing standing waves. The floor is concrete slab. The goal was to create a room capable of supporting low frequency production without over dampening the wall/ceiling surface, but yet maintaining good reflection control. The black cynlinders are Sonotubes covered in a nylon material which further aid in standing wave control. All electrical is on dedicated 20amp circuts. There are no windows and the doors (2) are solid wood. The dark blue color (chosen by my wife, thank you) makes for a space nearly void of ambient light. With all the equipment off, it is difficult to see a hand in front of you. The equipment is kept in a closet to the right. My system: Panasonic TC-P65V10, Pioneer Elite SC-27, Oppo BDP 83, DishNetwork VIP 612, Vanderteen 2C full range fronts, VCC-1 center, VSM-1 rears, V2W 300w powered sub, Audioquest speaker cable, HDMI interconnect. The television (all 147lbs) sits on top of a platform made from smooth fibre board stacked with cinder blocks and caps and painted high gloss black. It all makes for a pleasant movie viewing experience.
