DavidNighorn
- Jun 3, 2003
Hello all,
I have had my trusty AVM-20 running in my HT for nearly 7 months with nary a problem. This afternoon, I went into the theater and the processor would not turn on. After some mild panic, I removed the power cord and turned the rear power button off. Then I reconnected and turned the switch back on. Much to my relief, the unit came to life and appeared to be acting normally.
Except: There is no sound coming from it. The speaker test tones play fine but I cannot get it to play source material from any of my 3 sources. Clearly the amps are working because I am getting sound from the test tones.
Does anyone have any idea what is going on? Any suggestions on things that I can do? Thanks in advance for the help.
David
David
