akumaslair
Grip
- Dec 16, 2006
- Mike
I was asking a friend 1000 home audio questions, and he got peeved with me and directed this forum.
Firstly, let me apoligse in advance as I know ABSOLUTELY nothing about audio, and Im not old.. (26 y/old)... And I mean I KNOW NOTHING.
This is my situation:
Went and bought myself a relatively cheap Samsung plasma TV on impulse........
Took it home, found out it was a model without speakers.....
So I went to ebay and bought a relatively cheap set of speakers, bought it because the speakers were new, big, flashy, black and there were 5 of them.
oh well, not a problem, so I get home and try and connect the antennae to the tv, found out the antennae didn't go into the screen, call the shop and find out that I need to buy a set top,
Q1: why can I not plug the antennae into the screen like the old type of tvs
so I buy myself a settop box, and managed to connect it up relatively easily... got a picture straight away..quite happy. Tried to connect the speakers with the TV with the cables provided with the TV, however they don't match, the ones from the tv were the Red, White Yellow ones, the back of the speakers there is only 2 plugs and these ones don't fit on them anyway....So I call the shop again, and was told "you need an amp, and do you have a subwoofer"
Why can I not just connect the speakers to the TV just like a set of pc speakers, I had to go through the manual to find out that
I don't think I have a subwoofer although each of the speakers has a "5.5" woofer inbuilt"
so I need to buy an amp,
Q4. what sort of an amp do I need?
I am trying to get this up as cheap as possible, as we will be watching tv
and the odd dvd and thats it. nothing else.
I dont know how to describe the back of the speakers but the standard 3 Red, Yellow and White cables don't fit.
Q5. Do I need some special types of cables???
I am pretty sure that I will have more questions as I get the setup going........
Once again, thanks for any upcoming comments and feedback
