robsox
- May 11, 2009
- Rob
Hi all,
I've just received a Philips HTS565D Home Theater System from a friend and am trying to figure out the best way to integrate it with my other components but have run into a few issues so I thought I'd ask for some advice.
Basically, I would like to connect 2 screens (1 Projector, 1 HD LCD), a PS3, and cable box to the unit but there are no video inputs. I was looking at a Cables To Go 40697 6x2 Component Video Matrix Selector Switch on Amazon but wasn't sure if there was a better way as the projector (Mitsubishi HC1500) has HDMI and would require a 30ish foot run of component cable and the Philips unit is limited to 1 Coax audio in and 2 RCA type auxiliary inputs. Would the Sima VS-560 be a better option?
All of the units have HDMI except the Philips (it does have HDMI Out) so I'm unsure of my best option. Ideally, I would like to be able to use the 2 video systems independently, playing a game while watching a movie for example, but could live with bypassing the phillips for audio on the flat screen if necessary.
Thanks in advance for any thoughts or help you could give me.
Rob
Rob
