bsiegert9
- Dec 30, 2007
- Bryan
Comin to the gurus on this issue...
In about a month I am moving from a townhouse to a single family home. My current townhouse has a nice rectangle room which made my audio surround easy to run under the carpet etc.
Now... I am moving into a house that has a corner fireplace with TV shelf above the fireplace. Cable and power outlets are located above the fireplace as well.
I have 42" Samsung LCD and 5.1 Sony surround sound system (Yamaha receiver, HD cable box, and PS3 are all connected to each other).
The 42" TV will easily fit on top of fireplace, but now I am just lost on a plan to make my surround sound work! :frowning: :frowning:
There would enough room behind the TV, in the corner, for the component pieces to fit stacked (the TV would block everything sitting behind it)
I am lost on how to make the surround sound work!! Since you just can't run speaker cable down along the outside of the fireplace to the floor baseboards.
To paint a better picture of what I am working with... here is a pic of the actual living room from a real estate listing (sorry it isn't any bigger)
i11.tinypic.com/80y0jtd.jpg
It doesn't show the wall to the right of the fireplace... but the back wall is 13.7" wide. (It is 9' from the corner of the fireplace to the right wall corner)
Here is a simple diagram of the new living room layout.
i4.tinypic.com/80noqiq.jpg
I've never had to think about paying someone to run the speaker wire in a house before... can that be expensive? I am sitting with all my components... just trying to figure out my options to make it work in that above room layout.
Can the receiver sit hidden behind the TV, above the fireplace, and still connect to the sub and 5 surround sound speakers (wire going behind a wall and/or above the ceiling)?
Just tossing out some wishful thinking... would it be possible to have this sort of configuration??
i5.tinypic.com/6y0if01.jpg
Please offer any thoughts and ideas. I really had a simple room to setup in my townhouse... but this new room layout is worrying me.
I am not sure if something wireless would be effective? Just looking for some guidance!
Thanks a ton!!
Thanks a ton!!
