I have added the ability to modify your profile and edit your options that you use on the forum by placing a
and
icons under your username in posts.
This way if you want to turn the display of signatures off or change your time zone you can do it from your posts as well as from the main user control panel link.
The icons that are used to get to your user control are the only ones that you will have access to. No other member will have access.
Parker
Parker
