Matt_Smi
- Apr 11, 2004
- blank
This post is not for me, but for my uncle, I talked him out of Bose speakers and he is now looking for an alternative. The fronts and rears need to be satellites that can be mounted on brackets in the corners of the room, while the center can be full sized. After my advice he is going to buy the sub separate, and possibly will be going with either an HSU or SVS. His budget for the 5 speakers alone (not including the sub) is $1,000-1,200. The satellites do not need to be extremely small so small bookshelves may be an option here, but they must be able to be mounted in the corners of the room. He basically needs a package that has four sats and a (preferably full sized) center. I am looking for any recommendations here that will fit these criteria (and his budget). Thanks for any input!
