DavidZ
- Nov 20, 2001
I moved recently and decided to redo the HT room. Before it was in our family room now it will be in a dedicated room over the garage. The room is 19 wide and 10 high and 30 feet long. It is not a box as the roof line partly follows the roof of the garage so on the long axis it is very sloped over about 6 to eight feet. There is a double window on the long axis and one on the right side and a door at the end of the other long axis. I upgraded my processor to a onkyo nr5008. I have in reserve two adcom 565 monoblocks at 300watts each if that is not enough power.( not planning on hooking them up right away) The main speaker are mirage 3si they are bipolar speakers and Stereophile rated them a B speaker( no longer in production) the center is a mirage as well as the surrounds. The sub is a mirage bps 150( probably next to be upgraded) The TV is a new Sharp aquos 810 led 60" I will be sitting around 9' from the TV. The fronts will be about 4 feet into the room about 9 feet apart and 9 from my ears. I am uncertain what to do about the surrounds. In our old house I had them at ceiling level about 8 feet up just behind the sofa close to a wall with an opening into the kitchen. They were firing into the long axis of the room.
My question is should I put them a bit lower on the sloping wall or all the way back( about 15 5o 20 feet away closer to the back wall. I could get another pair or speaker eventualy to do 7.1 but want to keep it simple for now. The mirages have been awesome speakers and also with moving buying a TV and a processor there is no money for new surrounds right now.
