Todd Stout
- Jul 13, 1999
Hello all,
I have recently been having problems burning music CD-R's. The last several that I have burned have been skipping. I have tested some of them in both my truck's CD player and a home unit and they are skipping in the same manner in both. It's like the laser is having a hard time seeing the disc because they skip forward in increments of a few seconds. Also, each of these discs never seem to skip when I first put them in or in the same place every time.
This all started happening about the same time that I opened a new spindle of CD-R's (80 minute Memorex) so I thought that I may have gotten a bad batch. I bought a spindle of 80 minute TDK CD-R's and thought the problem was solved but one of the TDK dics is skipping in my truck's CD player now.
I just recently upgraded this PC to Windows XP from ME so I'm wondering if that may be the problem? I am using Easy CD Creater 5 Platinum and I have applied the patch that makes it compatible with XP.
The PC is a Dell Dimension 8100 (1.8ghz P4) that was purchased last August so I am hoping that the CD-RW drive isn't failing already. I'm not sure what brand it is but I do know it was not very expensive.
Do you guys have any ideas?
Thanks.
Thanks.
