Nevarthur
- Feb 21, 2016
- Nevil Arthur
Hi everybody,
I bought a Pioneer VSX 930 recently, and have had hours of frustration, and few hours of great sound, ever since.
Pointless telling you about my early set up attempts as they didn't go well, a bit of a learning curve encountered I think.
I have never managed to get sound from my Humax Freesat PVR, I have a couple times managed to get sound through the ARC HDMI connection from the TV to the Amp and out of the speakers but I don't really know how I did that, but was playing about with some command on the remote to do with outputs. Needless to say, I cannot often hit the right sequence to replicate this. The setup screen does appear on the TV screen. We have had the Blu-ray player working well, but sometimes I hit the remote for that, and you can see the player has started up and is on the main homescreen, but nothing has appeared on the TV screen until you do a lot of random fiddling with source buttons and the like.
I can listen to Internet Radio. I can listen to music on a USB drive. I know this amp basically works, so I'm assuming the problem must be me, right?
Last night I reset it to Factory Settings to start afresh. Using the Start Navi app on my iPad I plugged in cables (nearly all HDMI, plus co-ax from CD player, and optical lead from Freesat box. I hit the Freesat remote button and I get a picture, but not until I fiddle with the source button on the TV and select the exact same source that it was on anyway!
With a bit of fiddling, I can get the Blu-ray player working, although it's a bit random whether it turns off or on when I turn the receiver on or off. But it's not easy, there's still delays and luck involved.
I cannot make sense of the ARC setting at all, but I could not get the TV last night to output to the receiver the sound from the Netflix app I was watching so I could get it in the 5.1 it was claiming it was in, so I just have to use the sound from the TV (48 inch Samsung JE6400).
I find the manual annoyingly badly written. I cannot seem to perform the simplest of setting changes. I was never useless with hifi, I've always had separates, so why can't I make any sense of this product when so many people on the reviews praise it for its ease of setup?
I'm on a course for a few weeks which needs a lot of revising and I keep getting hung up on "just one more thing to adjust" on the amp in the hope it's suddenly going to start working but I never get anywhere.
Should it really be this difficult? Shall I concentrate on just one thing at a time? The Blu-ray, I'd like the BD player to work reliably, for now.
I would be astonishingly grateful for explanation links to easy to understand websites, first hand step by step instructions, general advice, and mild abuse. Thank you for taking the time to read this, and have a great day everybody.
