David Giesbrecht
- May 28, 2001
no I havn't everything looks fine as far as connections are concerned, but I have been wondering if wire gauge could be the cause of the problem.
You can add more frequencies and actually decrease the load on the amp causing it to keep from clipping. Add a 30hz tone completely out of phase with the first tone and then add any frequency you want with in the already set max power limitations and bam power in other places.If it is out of phase yes they will cancel each other but if they are in phase they will sum together to create double the amplitude.
(To different frequencies together will cause peaks and vallies in the output) Yes I fully agree with you on this statment. But like you said you will get peaks in the amplitude when the peaks of two frequencies line up in phase. It is these peaks that will cause the amplifier to clip.
When to frequencies of the same amplitude are joined together the amplitude of the new wave will be increased.
That is all I'm saying.
Did you have a chance to check the voltage output when the clip lights go on?No I havn't my dads tester seems to be busted:frowning:
I think it needs a new battery and I can't find one but if I do I will test it.
Conclusions, there is less required of the amp because some of the amplitude is now gone. The amp can create the other frequencies more accurately because the amp is less likely to clip.Exactly I think this whole thing has been a misunderstanding because in this statement you are agreeing with me. LESS FREQUENCIES = LESS AMPLITUDE
And I have been stating this the entire time! You can reverse it to MORE FREQUINCIES = MORE AMPLITUDE!
And I have been stating this the entire time! You can reverse it to MORE FREQUINCIES = MORE AMPLITUDE!This is wrong as well, see my above comment.
The amplitude of the waveforms sent to the driver is governed by the power that is capable of being sent to the load (driver) by the amplifier. Which you reach the limit of the amp's capacity to provide more current, you get the condition of clipping the amp where the waveforms get "squared off" and this creates sinewaves that weren't meant for the driver to reproduce (outside the 20KHz range for certain) being sent to the driver as the superposition (think of it as addition of a multitude of sine waves at very high frequencies to recreate the square wave condition) of these very high frequencies at high amplitude get sent to the driver with bad results.
Once you get to a clipping condition, all bets are off as to the amplitude of this frequency or that frequency being produced by the driver.
This is wrong. It's the current demanded by the load (driver) to power both frequencies at the amplitude that has increased.Either way the amplifier must produce more power.
http://www.eatel.net/~amptech/elecdisc/caraudio.htmIf you read section 84# it shows you in plain english with little graphs what happens when you COMBINE WAVES!
If your amplifier is producing half its power producing a single 100 hz tone and you at a second 1000 hz tone the amplifier will now be producing it's full power!
Read the article.
but try to hit them together and the same time (witch does happen!) and I had problemsThat would be like having two cd players playing at the same time going into a single input on a receiver. Twice the input signal, quite different from combining sound waves I think.
but try to hit them together and the same time (witch does happen!) and I had problemsI was merely saying that if I tried to hit both bass drum and snare drum at the same time the output of the board would clip but I could play them individually without a problem.
read more carefully please :frowning:
I was merely saying that if I tried to hit both bass drum and snare drum at the same time the output of the board would clip but I could play them individually without a problem.I won't get technical, because I can't, but that sounds like a much different situation to me than just combining sine waves.
I won't get technical, because I can't, but that sounds like a much different situation to me than just combining sine waves.But that is what were doing here.
The fundimental resonance of the bass drum on my drumset is centered at about 37 hz, the snare is about about 400hz plus all the overtones and undertones that come with it.
When I hit both drums together the sound the microphone hears is a combination of the two resonances and all the overtones/undertones mixed together to create a new more complex aggregate wave, when the two get mixed in the board the total amplitude of the audio signal (shown by the output readout on the soundboard) was increased.
when the two get mixed in the board the total amplitude of the audio signal (shown by the output readout on the soundboard) was increased.You should have said that a long time ago. That's your only example IIRC. But I am not going to keep arguing because I don't know anywhere near as much as those other guys.
BTW, I'm 17 too.
Did you have a chance to check the voltage output when the clip lights go on?I found a battery and the results are 36 volts
