Anthony Moore
- Jul 12, 2001
I really like the flat panel monitors, but I really dont want to sacrifice any quality just to save space.
When I look at the specs of a flat panel (im looking at a 19"), I see that most are about .29 dot pitch. My DELL 19" crt that I have now is .25. And Im having a hard time finding any flat panels that go that low.
Ive always thought the dot pitch was the telling tale on the quality of a monitor. Am I missing something? Cause I know ive seen some really good looking flat panels.
Also, I know that the resolutions only really go up to 1280 X 1024 (or somewhere in that range). Is this good enough for my HTPC? Is this capable of HD?
I guess when it somes to monitors I dont know so much. Can someone kindly point out the specs I should look for in a good flat panel? I would really appreciate it.
My brother works at Best Buy (DISCOUNT!), so if you could recommend one from that store it would be a definate bonus.
Im really just looking for the best picture for my buck.
THANKS!
THANKS!
