Mark-P
MASH was definitely not shot in VistaVision! The 1.5:1 aspect ratio to which you refer is 8 perfs shot horizontally. MASH was of course shot 4 perfs vertical which has an aspect ratio of 1.33:1 (silent aperture). All four sides are then cropped for release prints or video, which is why you are able to harvest more side image for the widescreen versions. There is also a lot more image on the top and bottom that you don't see even in the 4X3 version.Looking at the two shots closer, I'm now wondering what the original negatives could truly provide. The show was shot on 35mm, making the OAR 3:2. Which is close to 4:3 but longer on the sides. But in the HD versions there is significantly more information to the left and right, which leads me to think more information was captured on all four sides than we see in either version. Which, if correct, would mean the original frame was not as cropped as it appears on DVD, even if the show was cropped for 4:3 back in the day and the DVDs accurately reflect this.
If all of this is correct, viewers today would see everything in original 3:2, which large widescreen TVs could accommodate both in terms of aspect ratio as well as anything that might appear smaller without cropping.
Any thoughts on this?
