EricT
- Nov 28, 2001
Been hanging around here a lot (too much maybe) and have listened to many speakers I wouldn't have without you guys. Thanks. (I now know enough to just be dangerous.) I've narrowed my choice down to B&W CM4's ($1500.), B&W 804/805's ($3100/2000) and the JMLabs Cobalt 816 ($1700). Aesthetics are very important and so I’m leaning toward the 804.
Here's a plan of the room. Speakers in yellow. Can't move the tv location. No great spot for a sub. Rear surrounds are DefTech monitor200's (for now).
My question is: since the fronts will be so close, should I just go with a pair of 804’s and run in phantom mode with no center, no sub? Same money would get me the 805 bookshelf pair, the HTM1 center and maybe a sub. Use is 75% music/25% HT.
Will eventually go with separates but for now I’ll pick up the Marantz 8200 6x120W ($1300-thought I’d spend the money on speakers first). Is the Marantz capable of driving the 804’s? Can I bi-amp 4 channels on the Marantz to the 804’s and use the remaining 2 for the rears? I would then add a ~5 channel amp down the road when I get the center.
Am I way off base?
Thanks again.
-Eric
Am I way off base?
Thanks again.
-Eric
