Todd cc
- Sep 14, 2002
The IScan pro V3 line doubler will take Component,S-Video and composite interlace signals to Progressive Scan.
$500 shipping included.
The iScan Pro offers the highest video quality in its class using the latest video processing technology. In addition to all the features of the popular, highly rated iScan Plus V2, the iScan Pro includes the following enhancements for even better performance and compatibility with more TVs.
Component video input allows the iScan Pro to accept the highest quality video signal from a DVD player. Keeping the video in component form provides the maximum picture and color resolution available from a DVD disc to the display.
Picture controls, including brightness, contrast, saturation, hue and sharpness have been added, allowing the user the option of adjusting the video output for optimal picture quality on their display.
With multiple video standards support, users all over the world can now enjoy the best picture quality at an affordable price because the iScan Pro is designed to accept NTSC, PAL and SECAM sources.
Consistent with the iScan family of products, the iScan Pro converts existing standard-definition video from DVD, Laserdisc, videotape, satellite and standard broadcast television to a near high-definition signal. The resulting picture is dramatically improved with twice the vertical resolution and no flicker.
The iScan™ Pro - Feature Overview
Video Processing
Motion-adaptive video deinterlacing
Source adaptive processing
NTSC sources: Film (3:2 pulldown detection)
Computer graphics (30 frames/sec)
Video (60 fields/sec)
PAL/SECAM sources: Film (2:2 pulldown detection)
Computer graphics (25 frames/sec)
Video (50 fields/sec)
Source Transition Management provides seamless transitions between source types
Auto-dynamic thresholds enable reliable 3:2 pulldown & 2:2 pulldown detections even with noisy sources
Motion detection on per-pixel basis
Four input fields used to determine contents of each output frame
Cubic interpolation for pixel calculations
Diagonal processing reduces "jaggies"
Low-noise, high-accuracy 10-bit video DACs
Input Stage High-performance multi-standard video decoder
High-quality adaptive comb filter for two-dimensional Y/C separation
Video Input One S-Video input
One composite video input
One component video input
Auto sensing and switching
Accepts standard NTSC, PAL & SECAM signals
Video Output 15-pin VGA-type HD connector
RGB or YPbPr output colorspace
Separate H, V synchronization; composite sync; sync on green (or Y)
Output: 480p progressive scan video, 31.5kHz horizontal scan rate for NTSC input sources
576p progressive scan video, 31.25kHz horizontal scan rate for PAL and SECAM input sources
RGB - 0.7 Vpp, TTL Sync
YPbPr - 0.7 Vpp, Sync on Y-1.0 Vpp
Controls Input select/priority switch (1/2/3)
Picture controls: brightness, contrast, saturation, hue, and sharpness
Aspect ratio selection (Normal or Squeeze)
Output color space select (RGB or YPbPr)
Video Processing
