Anthony*gw
- Sep 4, 2003
Greetings, I am just about finished building my 140L sub,with it i will be using a Dynaco 400 stereo amp,it was my uncle's,i guess he doesn't want it anymore so he handed it down to me (lucky me),and i will be using the shiva driver that i ordered already but unfortunately it is not available right now,but i am willing to wait because Bob Reimer from creativesound said that they expect to have more by end of month.Since it's a stereo amp how should i wire shiva to get 4ohm load?
here are some specs for my amp:Specifications:
Power Output:
20 Hz to 20 KHz, both channels driven:
200 watts continuous average per channel @ 8 ohms;
300 watts continuous average per channel @ 4 ohms;
100 watts continuous average per channel @ 16 ohms.
Monophonically:
600 watts rms @ 8 ohms.
Intermodulation Distortion: Less than 0.1% at any power level up to 200 watts rms per channel into 8 ohms with any combination of test frequencies. Distortion reduces at lower power levels. Typically less than 0.03%.
Harmonic Distortion: Less than 0.25% at any power level up to 200 watts rms per channel into 8 ohms at any frequency between 20 Hz and 20 KHz with both channels driven. Distortion reduces at lower power levels. Typically less than 0.05%.
Power at Clipping, single channel, 2500 Hz, less than 1% distortion:
235 watts @ 8 ohms;
350 watts @ 4 ohms;
135 watts @ 16 ohms.
Ppower bandwidth: 5 Hz to 35 KHz at less than 0.25% total harmonic distortion - half power output, 8 ohm load.
Frequency Response: +0, -1 dB, 8 Hz - 50 KHz @ 1 watt into 8 ohms; ±0.5 dB, 20 Hz - 20 KHz @ 200 watts.
Hum and Noise: Better than 100 dB below rated output, full spectrum.
Input: 50,000 ohm load; 1.6 volts for 200 watts @ 8 ohms.
Slewing Rate: 8 volts per microsecond.
Damping Factor:
Greater than 80 to 1 KHz into 8 ohms;
Greater than 30 to 10 KHz into 8 ohms.
Channel Separation: Greater than 60 dB by IHF standards. sorry for the long post.
Power Output:
Monophonically:
235 watts @ 8 ohms;
350 watts @ 4 ohms;
Damping Factor:
